Setting up a website on my WHS 2011?
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
I'd like to set up a website using my server that's on 24 7 for family photos etc. Are there any free programs worth looking at? If not, what's worth looking at within a reasonable budget ... no more than £50 ideally!
Cheers,
Jed.
Bit confused.
With WHS2011 you get a website (kind of).
It gives your users permissive access to shares on your WHS. You can customise a background image too.
If you shares the photos then they can view them, or download them if you give the appropriate permissions.
What more do you want from it?
WHS 2011 already has a small site set up when you install it for downloading the connector software. I think it's setup using IIS.
