- 20 Aug 2012
- Greater London
i'm a bit new to the idea of CUDA cores, and after hearing that they can reduce rendering times considerably, i decided to download the toolkit from the nvida website. i've installed it, but 3ds max (3D modelling program) still appears to reject my gpu when i try rendering with it. i get this when using iRay Renderer:
IRAY 0.8 warn : ignoring unsupported lens shader type "max_base_GBuffer_lens"
IRAY 0.8 error: CUDA device 0: invalid device symbol
IRAY 0.8 error: CUDA error on device 0, cannot use this device for rendering
IRAY 0.8 error: rendering fragment failed on device 0
IRAY 0.8 error: CUDA device 0 failed during first frame, deactivating it and re-rendering now
i have an nvidia gtx 660Ti, with 3GB memory, so it should work fine.
Am i doing something stupidly wrong, or is there a different problem here?
