setting up dual monitors
10 Jul 2006
Liverpool
Hi guys ive just set up my dual monitors (lcd for windows stuff and crt for gaming). i was wondering if there was a way to tell the pc to output the games stuff on the secondary monitor only without having to set it to primary all the time? my card is a radeon 1900xt
any help appreciated.
Si
Some games will let you select the card to use as your graphics adaptor, normally in a drop-down menu. Your CRT should appear as "RADEON X1900 Series - Secondary" or something similar. Selecting that should make it appear on your second monitor.
Admittedly not many games do that though...
^^^ but very VERY few games do this :(
For the most part you'll need to set it as primary or just stop being a big girly girl, man up and play on the TFT cause I promise you it WILL look better :>
it looks sharper and stuff but the motion blur im just not used to it :( makes me a bit quesy plus i cant whack it out at 1600 res on my tft :p
