setting up fans in new case.
23 Oct 2014
Hello,
I have ordered my Obsidian 750D (should be her for 15/11/14) and also some Corsair fans.
2 Corsair SP120mm white LED fans
2 Corsair AF140mm white LED fans
I am going to use the 2 Corsair SP120 white LED fans in a push pull configuration on my Cooler Master Hyper 212 Evo pulling air from the front of the case and pushing it to the rear.
I was thinking of using 1 of the AF140mm and replacing the top front fan and the other to replace the rear fan.
Use the replaced rear fan at the top rear to exhaust and the other from the front to intake from the top front.
Use 1 off the 120mm Cooler Master fans from the 212 evo as a intake (with filter) on the bottom.
Will this fan setup be any good for maximum air flow and keeping the case positive pressure?
Thanks,
worf105
