Hi guys,
I'm trying to set up a Guest WLAN to be completetly separate from our network and only allow internet access. The line I want to use has a Draytek Vigor 2800 router, and I have a Ruckus 2942 wireless AP. Both units support VLANs, but I have no clue how to configure them - have never needed to mess with VLANs before!
Draytek have this on their support site: http://www.draytek.co.uk/support/kb_vigor_vlan.html
It sounds great in principle, but how to set it up in practice? I understand that those options there will set for example switch port 1 as VLAN1, and port 2 as VLAN2, but how does it work, I can't see a way to configure VLAN1 to be on say 192.168.0.x and VLAN2 to be on 192.168.1.x, or am I completely missing the point?
For our main network, our file server is the DHCP server, so ideally I'd like our wireless AP to sit on VLAN 2 and serve DHCP, to have a subnet of 192.168.1.x.
The Ruckus unit states that it supports VLANs in much the same way as the Draytek, I can't see a way of separating the IP addressing.
I'm confused.
Any help would be much appreciated!
I'm confused.
