Setting up HDD. Qucik help needed.
6 Feb 2008
I got 1 HDD that has OS on C:
and another that has all my documents on E:
I know if i start saving files they will automatically save onto the C:. So how do i set i up so anything i save will automatically save on to the E:
p.s. IDE connecetions. C: is the master and E: is the slave.
Thanks
Do you mean to your My Documents folder on the C drive? You can right click on it on XP and change its location, this will normally be where most save windows open.
In Vista Im not 100% how you do it. If you go to Administrative Tools>Computer manager>Local Users and Groups>Users>bring up the properties for your user and change the home path to E:\ shoudl do it.
It's XP.
I currently have two HDD
C: Has os installed- with all user profiles
E: Which is empty just formatted it
I wont to have C: just for OS files
E: for everyone documents.
I.E they would go into E: to load a word document that was saved.
or
When buy music of Itunes it will automatically save into E:
Document and setting is the folder.
When i right click there is not an option to change its location
C: For boot
E: for documents
