- 3 Mar 2010
- Highlands, Scotland
Hi guys,
I am using VMWare Go to deploy Hypervisor to a server I plan to run a couple of virtual machines on.
The Spec is decent (plenty RAM etc) and it passed the initial hardware scan and deployed ok, but upon reboot it had a problem with my PCI Network Card.
It said it was already in use or unavailable.....google revealed it was prob unsupported.
Can anyone suggest a decent NIC I could use that would work well with Hypervisor? Low profile would be nice
Intel's Pro 1000 seem to be a good choice but I'm on a bit of a budget at the moment
