Setting up memory
13 Nov 2009
I am trying to set up my memory and noticed that in cpuz it says my memory is single channel when it is actually dual:
I have OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 Dual Channel.
Any one know what BIOS settings I should be using? All I have done so far is set the clock to 800mhz and copied the memory timings from the overclockers description. Is that the right thing to do.
Very confused. :confused: Any help would be amazing.
Solved:
the letter refers to the channel. So putting ram in a1 and a2 is putting them both into a single channel. I put my 2 into a1 and b1. Now cpuz reads dual channel.
