13 Oct 2011 at 09:43 #1 Gandeh Gandeh Associate Joined 21 Jul 2011 Posts 545 I got the last of my parts today and I'm setting up my rig as I type. Does it matter what PCI slot I use for my GFX card?
13 Oct 2011 at 09:44 #2 Admiral Huddy Admiral Huddy Man of Honour Joined 17 Feb 2003 Posts 29,640 Location Chelmsford Yes, normally the one nearest the CPU IO plate. Check the manual.
13 Oct 2011 at 09:45 #3 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 Gandeh said: I got the last of my parts today and I'm setting up my rig as I type. Does it matter what PCI slot I use for my GFX card? Click to expand... Hopefully you'll be using a PCI-E slot unless you have a really ancient card. You should use the top slot nearest the processor.
13 Oct 2011 at 09:46 #4 Gandeh Gandeh Associate OP Joined 21 Jul 2011 Posts 545 I was flicking through the manual like mad but couldn't find the section for it. Okay that's great thanks I'm using a GTX 580 pics to follow!
