- 14 Jul 2012
Was planning on purchasing the H60 so I can start overclocking, and since the only place in my case to install it is as an exhaust I was wondering if setting up push pull would improve efficiency.
I was going to use 2 corsair static pressure 120mm fans either side of the radiator.
Anyone got any advice?
Using the GA-P55-US3L motherboard.
