Setting up VLANs
16 Jan 2008
Having large problems trying to setup some VLANs on my 3COM 2920 switch (HP Procurve V1910).
It connects to the Internet via a Draytek Vigor 2920 (WAN router).
Here is what I'm trying to achieve:
Code:
Port 1         -   VLAN1,VLAN3
Port 2/13     -   VLAN1
Port 14       -    VLAN3
Port 15/16   -    VLAN2
Basically the Internet comes in on Port1, and will be distributed to wired network (VLAN1) and wireless network (VLAN3), as I don't want the wireless network to be able to access certain things such as the NAS server. Then ports 15/16 (VLAN2) are between my server and NAS (as it is an iSCSI connection).
How would I go about setting this up?
Cheers
No idea of the commands you'd need to type on a 3COM Switch I'm affraid.
On a Cisco device, you can't have a access port on two VLs (well you can with PVLANS). So, you'd need to trunk Vl 1 and 3 between your Switch and RTR and then make your access ports members of the VL you want. Remember, you will also need to Route between the VL's to allow internet traffic to flow (Router on a stick or a L2/3 Switch).
I may be easier to use a Router to seperate the two Networks.
