- 20 Dec 2015
- Hertfordshire
I am in the early stages of evaluating Windows Server Essentials 2016. My existing Windows Home Sever 2011 is no longer supported or getting Microsoft updates so a change is required. So far I have installed the OS, setup an admin user, setup a couple of standard users, setup disk pooling, setup some shared folders and eventually got remote desktop working. I've done everything within the dashboard and only used Server Manager to fix RDP issue.
During installation I setup a domain in name only and have had no further contact with domains or active directory setup and im hoping this continues but I haven't connected any devices yet so this will be interesting. I have found a registry change from Microsoft that you run on the client PC before installing the connector that tells the PC not to join the domain or use the server for DNS, apparantly this doesn't stop the PC from being automatically backed up and doesn't stop the PC from using the shares on the server. Seems very WHS2011 like! Has anyone any experience with using WSE2016 as a home server without getting involved with domain etc? Any tips would be welcome before I do any damage!
Thanks
Thanks
