- 5 Aug 2006
- Kent, UK
Hi,
So i've decided to foray into the world of linux for the first time and have installed XBMCbuntu onto my HTPC.
I'm having some teething issues getting to grips with the hard drive mounting system.
So i have two HDDs, an 80GB one which XBMCbuntu is installed onto using ext 4 file system. I'm now trying to add a second internal HDD (1TB) where my media will be stored. (currently all my media is on my windows 7 desktop; the ubuntu HTPC, win7 desktop, plus other windows machines are all networked)
My plan at the moment is to plug the media HDD into my windows 7 pc, format with a suitable file system, copy all my media onto it, then plug into my HTPC downstairs.
Is this the simplest way?
Which file system is most suitable for using with ubuntu and windows? Fat32 or NTFS?
Will XBMCbuntu automount the media HDD and allow me to access the files on it, if not, how do i do that?
The HTPC will be set to WOL, and I will use it to stream media to other windows PCs around the house. Apparently i can use Samba to do this.
Any tips for getting this to work well?
I would like to be able to give all users read only access, apart from my own PC which will need read/write access.
Many thanks for your help.
