Hi guys,
I'm not sure how many boards support this but I've seen some of the P55 boards with the option. I'd like to reduce the idle draw of my machine when overclocked and this option seems convenient. On my P7P55D my i5 750 will run rock-steady at 3.6GHz with a vcore of 1.2-1.22v ish. However, when Speedstep kicks in on idle and the multiplier drops down vcore remains the same.
If I set the voltage to 'auto' the machine appears stable but I'm not really sure how the voltage is determined, so I'm a bit wary of using it! It's definitely higher than the voltage at stock though. eg at 3.6 vcore is ~1.28v. When the machine idles vcore drops, along with the voltage.
When using vcore in 'offset' vs 'manual' mode with the offset at 0.1v, when one core is fully loaded it runs at 1.2v, four cores gives 1.24v.
Anyway - what's worrying me is the clock/multiplier change does not happen at the same time as the voltage change, and this appears to make the machine unstable. It will often step up from 1.8GHz to 3.6GHz but keeping the vcore at 0.9v for a several seconds...
Does anyone else use this offset method? Any info or advice?
Cheers!
Cheers!
