Hello,
After my old RAM had a short life expectancy due to using the advertised settings I was wondering if you guys could give me some help with the current settings for my new GeIL PC2-6400 800MHz please?
I've installed the sticks and doing a MemTest to make sure everything's ok. I am using the optimised defaults for the first run.
The stick's label says 5-5-5-15 with 1.8v.
My motherboard has set the timings to 5-5-5-18 and seen as the normal memory voltage is 1.8 I think I'll only need to change the tRAS to 15.
Does that sound about right? I'll run the MemTest again when I make the simple change.
