Settle a dispute?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
I'm currently discussing the answer to this question with a mate, and we are at logger heads over it.
Divide 200 by half and add 30? What do you get?
Using your mates logic he's still wrong, using the "and" to mean as well as, you'd need to add the 30 to the half number before dividing, so you'd get 200/(100+30) which equals 1.538461538461538, otherwise the challenge would say "and then add".
It is 430 but it's ambiguous enough that I've already seen a few engagement farming posts and videos based on similar, in the last day or two.
If the question read divide by half of one then I would agree 430, but the question reads as if the the answer should be 130.
It's all in the wording and interpretation.
