Setup advice
16 Aug 2004
Hi,
I need some help, Im in the process of changing from a "wireless sdsl connection" to ADSL through a BT phone line.
I use the connection mainly for gaming.
I already have a Linksys WRV54G wireless vpn broadband router. (works fine)
My desktop is wired to the router.
What would be better;
To buy an ADSL modem (such as Linksys ADSL2MUE ADSL2 Modem with USB & Ethernet) and attach that to the router?
or
To buy a new ADSL router?
Also
I want to go completely wireless (as socket not nearcomputer, and BT want £110 to install one)
Is a wireless PCI card all I need fo my main PC (previously wired)?
Basically Im trying to suss what is my most cost effective and fastest solution.
Edit: My new ISP are offering "Billion 7402VGP VoIP/802.11g Wireless Router" for £80, would this be a good option.
Thanks
Ed
Probably as cheap to buy a new ADSL router, even if you buy a wired one and connect the wireless router you've got.
