Hi All,
Have to replace my pump and wanted to add another GPU, just wanted to check that my setup is correct.
http://postimg.org/image/r1ux5o2e5/
The brownish colour is the proposed setup.
The GPU WC blocks have 4 entry/exit points. So if you are looking at it sideways (from left to right) there are 1 2 at the top and 3 4 on the bottom.
With one GPU I used 2 as entry and 1 as exit. Now with 2 GPUs would the correct way be to use this:
Enter GPU 2 at 4 and exit at 1 to enter GPU 1 at 3 and exit from 2?
Any help would be very much appreciated. Thank you very much in advance!
~Krillian
~Krillian
