Setup is stuck is a restart loop. please help
27 Sep 2009
Here is the setup
AMD 6000 3.0 GHZ X2
M2N-SLU DELUXE
CORSAIR 800MHZ RAM
GTS 250
500GB HDD
Here is what happened first.
1. setup started up fine and indicated cpu has been changed and press f1 to continue
2. asked for bootable disc so i put in win 7 32 bit rc.
3. go to the screen where you have to click 'install now' (after you select the language)
4. setup just entered restart loop. ( fans spin up then power down, spin up, power down spin up and power down etc...)
any ideas would help
thank you
Is it OC'd at all?
Can you get back to the setup screen or does it just restart before POST. If it does restart before POST I'd suggest clearing the CMOS.
Is it OC'd at all?
the setup has not been oc'd at all.
will clear the cmos and get back to you. thanx
Reseated the CPU? Try with 1 stick of RAM if possible too, might be the voltages are out by default.
Ok I'd try one stick of memory at a time then.
Did you try disconnecting your power button?
might be worth building it outside the case to check somethings not shorting out
hi
have done the memory thing.
ive built it outside the case
i think it might be the power supply. when the setip is turned on the fan on the psu stops as well. or is that not it
could it be a faulty mobo. ive changed the cpu as well
