Setup program running on startup
2 Oct 2007
Oxfordshire
Hello everyone, didnt really know where to put this problem so thought I'd place it in here.
I recently installed a G15 Teamspeak application for my keyboard, yet now as soon as I turn my PC and it gets to the desktop screen, I am greeted by the installer file:
http://s48.photobucket.com/albums/f206/carrot1401/?action=view&current=g15problem.jpg
Its a tad annoying, I tried turning off some startup programs in startup in msconfig (although not much as I dont want to turn something important off), deleting temp files, using CCleaner, uninstalled the app altogether and it still greets me and is just getting a tad annoying. Any ideas on how to remove it??
The bottom ones have all been turned off as I know I don't need them...
You could safely disable the qttask, iTunesHelper, Reader_sl, ctfmon, Steam and Adobe Gamma Loader anyway.
After that just disable one at a time of the remaining ones and then reboot. See if the installer starts again. Keep choosing one to disable until you find it.
