Installed a fresh copy of server 03, built my domain, got the users, got the computers. Now having a play with group policy as per active directory users and computers.
All I want to do is to have everyone have the same background, I navigate to the active wallpaper GPO and specify where the file is, enable it and enable-disable change active desktop wallpaper.
My users are in an organisational unit (I even put the computers in there as well to be on the safe side)
Log on, log off .... do a gpupdate /force on the server and for the user (we'll say just 1 for now to make matters easy) on the 2nd computer that i've got. The GPO just won't seem to pull over :s
1 of my pc's have 2000 pro, the other xp pro. Both log into the doman fine, but even if I try and create some other GPOS and enable them, they won't pull over !
I've had a check to make sure nothing is contradicting eachother, also been on you tube to make sure i'm doing it how everyone else does it, and their GPOS work and mine dont !
Please Help :s
Thanks
Please Help :s
Thanks
