Sever 2016 backup GUI disappeared
Ish
Ish
11 Jan 2006
West Midlands
Hi
We have Server 2016 Standard but Windows Server Backup has disappeared from it.
According to Roles/ Features it says Windows Server Backup is installed but I can't find it anywhere.
I have tried removing and adding the feature again but I still can't see it.
If I search for 'backup' in the search box nothing comes up. I found a cmdlet command on Google which checks so see if it is installed and it says it is.
Code:
PS C:\Users\xyz> Get-WindowsFeature -Name *Backup*
Display Name                                            Name                       Install State
[X] Windows Server Backup                               Windows-Server-Backup          Installed
Thanks for your input but I want to use the GUI interface which is what has disappeared.
wbadmin allows you to interrogate the backup in any way you wish, the GUI is not required. I can't understand why you cannot see the GUI but it isn't required.
