- 17 Jan 2006
I wonder if anyone would be kind enough to gie me some advice on what motherboards and processors I should look at for building a small pc.
I know this is a huge question so I shall give as much info as possible.
My intention is to build a small pc into a piece of furniture to go in a lounge/sitting room. I'm currently thinking I'd like it to be a small cube (possibly) shape wooden box that could be used as a coffee table as well as containing the PC.
My intention for the PC is for it to run some software called Media Engine, which is, as the name suggests, a piece of media software (ie music and video playback). Really it is intended for use in car pc's but I use it on my home PC for all my music playing and it does everything I want it to and it does it well.
I have the software running really nicely on a P3 866hmz with 256MB RAM and a Geforce2mx graphics card, so I won't be needing the latest technology really and I don't need anyt thing mega powerful.
Ideally I'd like the unit to remain fairly cool so I don't have to use fans, or could use low speed ones if necessary, so if there are any board/CPU combos that I should avoid please let me know.
I would need to have a network connection for the comp so would need to be either built on or I could use a network card. Also I would want a decent sound card so would need a PCI slot for that.
Going from this info, can anyone recommend me anything???
Ta muchly for any help, it would be very much appreciated.
Valve
Valve
