Hi, im intending to put together a budget SFF PC in the next few days to use primarily as a server, hence no real need for anything more than onboard video, f that.
Ive been looking at AM2 and a 3800+ combination, but after hitting these forums I see theres a massive buzz about conroe. Im intending for the system to be somewhat upgradeable. Heres my initial Plan:
Asus V2-AH2 AM2 MATX Barebone System (Seems to be the best value for money) £83.17
http://uk.asus.com/products4.aspx?l1=1&l2=1&l3=0&model=1159&modelmenu=1
AMD Athlon 64 X2 Dual Core 3800+ 2.00GHz (Socket AM2) - Retail (CP-166-AM) - £105.74
Corsair 2GB DDR2 XMS2-5400C4 TwinX (2x1GB) (MY-095-CS) £140.99
Maxtor DiamondMax Plus 10 NCQ 250GB 6V250F0 SATA-II 16MB Cache - OEM (HD-088-MD) £55.81
Total: £385.71
Im looking todo some mild overclocking on the system, but I have say this will be pretty much headless most of the time, unless I decide to add a GFX at a later stage and make it more than a server.
Does the specification look ok? Specifically would the included PSU suffice, or would u recommend a replacement?
Does conroe really offer such a massive boost in performance over the X2's? Alternatively if anyone can price a similaly priced conroes based system, or better specification AM2 for the same price, id be extremely grateful.
Many thanks, im new to both SFF and AM2 / conroe, so help is much appreciated.
Total: £385.71
