28 May 2009 at 11:22 #1 lixxus lixxus Soldato Joined 20 Oct 2006 Posts 2,595 Location London can anyone recommend me a SFF ATX case large enough to fit a full sized graphics card for example GTX 275? my budget is around £100 thanks
28 May 2009 at 17:42 #2 hawker1986 hawker1986 Associate Joined 19 Mar 2009 Posts 1,643 Location Leicester Presumably you mean micro-ATX, full ATX and SFF do not go together? Hawker
28 May 2009 at 19:31 #3 JonJ678 JonJ678 Soldato Joined 22 Dec 2008 Posts 10,369 Location England lian li a05n is about your only choice mate
28 May 2009 at 20:07 #4 pingwing pingwing Soldato Joined 9 Apr 2008 Posts 19,758 Location Bedford Silverstone sg03 can take one i think (iv got a gtx 280 in it)
28 May 2009 at 20:23 #5 lsg1r lsg1r Soldato Joined 25 Jan 2007 Posts 4,804 Location King's Lynn theres a version of the sg01 and sg02 which can take full length cards but you do need a matx motherboard
28 May 2009 at 21:36 #6 Guardsmon Guardsmon Associate Joined 4 Sep 2006 Posts 1,843 Location Bristol mini-itx will take full length gfx cards if you get a case that will. alll depends on the case you want really. as previously said the A05N is your best bet for ATX board
29 May 2009 at 19:41 #7 lixxus lixxus Soldato OP Joined 20 Oct 2006 Posts 2,595 Location London i think i found something i want. its the cooler master gladitor 600. i just hope that overclockers stocks it soon
