Im looking to build a SFF system to fit inside the cabinet beneath my TV. It is for light HTPC / Gaming / iPlayer / server use and so must be versatile!
I have the following parts spare:
HIS IceQ 4670
WD Green 2TB
Copy of Win7
and am happy enough with the performance of the 4670 as my TV is only 1366x768.
Im thinking that a build around the new sandybridge pentium G620 would probably suffice with a H67 mITX or mATX MB (both seem to cost about the same).
The cabinet is 205mm high, 390mm deep and 475mm wide - although the door to the cabinet is only 430mm wide so would pefer if the case was <430mm wide.
So, on to my Question!
What case would you recommend for the above?
I've been looking at either:
a Silverstone GD04/05 (would need to remove shelf and above items to jimmy it in through the 430mm wide door!); or a
a Sliverstone SG03/04 (on its side - would this work?)
Thoughts / opinions?
HIS IceQ 4670
WD Green 2TB
Copy of Win7
Though you'd need another hard drive.
