SFF case for a AORUS 1080ti
13 Mar 2005
Can anyone recommend me a case that will fit a aorus 1080ti card.
The cards pretty big so I'm limited to what SFF case I can build in.
Can anyone recommend anything please not too expensive.
Thanks
Fractal Design Node 202
Silverstone FTZ01, RVZ01, RVZ03
Aside from that, you're looking at expensive small batch cases and imports.
Im looking for a cube style case ideally. Something like a Silverstone SG13B which supports MATX boards and will fit my 1080ti.
I misunderstood. Thought you were after ITX.
If you're after a Micro ATX cube case then surely this is pretty easy? The Aorus 1080Ti isn't unusually long. It's just wide. Take a look on Silverstone and Fractal Design's websites and you'll find a decent selection of MATX cube cases.
If you like the SG13 then the SG02, 09, 10, 11 and 12 are likely good starting points.
sliger ! have EU distributor as well. have ITX cases that can accept triple slot cards with or without Water support
know your away around a dremel. Silverstone RVZ03 and cooler master VGA bracket and done !
Ive using ITX board , then two slim 120mm at the rear as exhaust and cut a grill in the side panel :D
