SFF Case - Sugo SG06 Alternative?
15 Apr 2008
West Didsbury, Manchester
I have been looking for a suitable mini-itx case to go under the tv to replace my Lian Li C37B. I want to include a decent graphics card (looking at the 550ti) and stick an i3 in there. Now the components aren't bothering me at the moment but the fact that the only suitable case I can find is the Sugo SG06. Is there anything else that is the same sort of size (or smaller!) can take a decent graphics card, runs a 400w PSU and doesn't cost upwards of £120?
Search SG05B 450w on google.
Its a SG06 with a different front, special edition, black painted innards and comes with a 450w PSU. Can fit 9-10" GPU. That means 570 range GPU will fit.
A competitor had them for £103
Ok I sucked it up and finally bought:
Sugo SG06 BB-450w SFF Mini
Asrock H61M-ITX H61 Socket 1155 ITX Motherboard
Intel Core i3 2120 3.3GHz Socket 1155 3MB L3 Cache Retail Boxed Processor
Kingston HyperX Genesis 8gb
Going to try and pick up a cheap 560ti in MM and then find a 3rd party CPU cooler for it. Any suggestions for CPU coolers that will fit a Sugo SG06 when a possibly full sized GPU is installed.
