24 Aug 2020 at 20:30 #1 KHALIK KHALIK Associate Joined 29 Apr 2003 Posts 496 Location London, Forest Gate As the title says: SFF case that’s supports ATX PSU Any recommendations?
24 Aug 2020 at 21:03 #2 KHALIK KHALIK Associate OP Joined 29 Apr 2003 Posts 496 Location London, Forest Gate I will not be using a gfx card and need a small case to house my existing ATX PSU.
24 Aug 2020 at 21:07 #3 koolpc koolpc Soldato Joined 2 Dec 2004 Posts 14,807 Location Under The Desk, Wales Depends on style of case. Quite a few available.
28 Aug 2020 at 16:42 #4 neepheid neepheid Associate Joined 2 Jun 2020 Posts 48 Location Aberdeen, Scotland No GPU? Jonsbo T8 will take an ATX PSU (although you will be compromised on CPU cooler height)
29 Aug 2020 at 22:45 #5 KHALIK KHALIK Associate OP Joined 29 Apr 2003 Posts 496 Location London, Forest Gate Thank you
30 Aug 2020 at 11:18 #6 neepheid neepheid Associate Joined 2 Jun 2020 Posts 48 Location Aberdeen, Scotland Also, a small GPU (< 210mm in length, I think - check the specs) can be fitted in this case if you wanted to add one down the line.
12 Sep 2020 at 09:39 #7 ver01@ ver01@ Associate Joined 7 Aug 2017 Posts 1,924 Location Oxford Cheapest decent one Kolink Satellite.
12 Sep 2020 at 10:06 #8 Furyus Furyus Associate Joined 15 Sep 2010 Posts 1,027 Location Weston-super-Mare I've got the fractal design nano S, and it houses my ATX Psu perfectly!
12 Sep 2020 at 11:42 #9 Obijuan Obijuan Associate Joined 19 Aug 2016 Posts 32 Silverstone SG13 Thermal take Core v1
12 Sep 2020 at 18:41 #10 bol bol Associate Joined 6 Feb 2018 Posts 104 https://www.overclockers.co.uk/silv...zN5sOd12P3nd_17O6OSJyCnLVQJDC92BoCsm0QAvD_BwE Have an earlier one at a great price, had to buy a sff-l psu for it though
12 Sep 2020 at 18:45 #11 ver01@ ver01@ Associate Joined 7 Aug 2017 Posts 1,924 Location Oxford Probably makes more sense buying a NUC or similar if are not planning to install a GpU
10 Nov 2020 at 23:14 #12 gam3r gam3r Soldato Joined 20 Jun 2005 Posts 3,826 Location London.. Metis plus
29 Nov 2020 at 15:58 #13 s k s k Associate Joined 16 Aug 2019 Posts 100 Nr200 and get someone online to 3d print you an atx bracket
29 Nov 2020 at 15:58 #14 s k s k Associate Joined 16 Aug 2019 Posts 100 The bracket design can be found on cooler master website
