SFF for these parts
1 Feb 2009
Im thinking of downgrading the size of my tower to a SFF, i currently dont want to spend lots of money and re-use as many of the parts i can. Below is a list of the parts id like to re-use. Havnt used a SFF since my MSI 651 and would like to have another as i found them great little machines
C2Q Q8200
DDR2 2x2Gig
Blu-Ray Drive
ATI 4750
500Gig + 1 Tb Drive (Both SATA)
ASUS Xonar DG PCI
So i would require a new mobo, PSU and case that would run the above, while being cheap, say 150 or less if i can get away with it.
Thanks
Is the BluRay slimline or 5.25"? And is the GPU single or twin slot?
If you need more than 2 PCI slots (with the Xonar) you'd be looking at M-Atx as opposed to M-Itx and could look at cases like the Lian Li V351B, which also takes a standard PSU. Many more options available with boards too.
Try and get a secondhand sugo sg05 and zotec itx 9300 board. Both should be ~£50 each.
I agre with this but for the fact that he won't easily be able to fit two 3.5" HDDs in a SG05. If I was the OP I'd sell the smaller HDD and put it towards a 2.5" drive, preferably SDD.
Personally I avoided uATX as I was of the mindset that if I wanted to go small, I wanted to go as small as I could.
Ah sorry forgot to mention the blu-ray is full sized at 5.25"
GPU is single slot
edit: M-ATX might be a better solution so i can re-use the H50 for cpu cooling, so, any hints on what i could use
