SFF-ITX for buisness use (software/electronic development).
7 Mar 2010
I need a new computer for business use. This needs to be small as Ill occasionally take it places, have plenty of USB connections. I will be running a couple of virtual machines occasionally but mainly just doing software development and some CAD work (tiny bit of 3d). Ive got a 128GB Crucial SSD and Ill use my old Nvidia 8800GT for now. Id ideally like to keep costs as low as possible so Im just looking for the best performance/cost thats realistic. Be nice if it wasnt too power hungry too (cant have everything though ;) ).
Silverstone Sugo SG05 HTPC Case with 450W Power Supply - All Black ( SST-SG05BB-450 USB 3.0)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-127-SV&groupid=2362&catid=2279
£114.95
Asus Z87I PROFESSIONAL Intel Z87 (Socket 1150) DDR3 Mini-ITX
http://www.overclockers.co.uk/showproduct.php?prodid=MB-580-AS&groupid=701&catid=5&subcat=2071
£145.99
Intel Core i5-4570 3.20GHz (Haswell) Socket LGA1150 Processor - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-476-IN&groupid=701&catid=6
£155.99
Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=CD-124-SA&groupid=701&catid=10
£17.99
Memory; 2x8GB not sure which?
Would a 300watt PSU would be enough to save money?
Is intel the way to go for performance?
Thanks for any advice.
OK thanks, updated CPU to Intel Core i5-4570.
I only need two SATA ports, optical drive and SSD. Another would be nice if I decide to mirror the main disk in the future but I probably wont.
I like the fact that board has 10 USB ports on the back. Given the case is small, makes it easier with all the equipment I have (which all connects via USB). It is pricey though, £70 is much better...!
