Hi all,
I'm after a cheapish solution to a home IP Camera issue.
We are running several concealed IP cameras and obvious NV IP cams around the property and are needing a system that can be setup in the following parameters:
- Backup (RAID ideally)
- Constant record of multiple streams
- Minimum power due to always-on
- Fast enough to allow data/vid to be streamed to any device on the network for checking the video
- Low noise and low heat generation
(RJ45 spec network)
Does such a list of specifics exist in one system?!
Thanks![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
(RJ45 spec network)
Thanks
