- 1 Dec 2015
Matx- Pretty Little Alumin
Thought id attempt a 3rd build after the previous White and Black Hybrid builds, but with this time around, less Hybrid modding and straight up off the shelf, easy to use watercooling gear.
was going to set out to make a fully watercooled RVZ01 console case but would have had clearance issues of 1mm !!! could easily be solved but not really interested in swapping multiple water kit brands to get it done.
So attention turned to Small Forms that visually looked awesome but could handle a full watercooled system !
Saw the New MSI white Mortar B150 Matx Board and thought it was a great base to work with visually, next up was the case... found one! only issue was the colour.... US only
System would be based on an i5 6500, 16GB DD4 along with Samsung 950 256GB/ 1TB SSHD and using a Zotac GTX 1060 which would be watercooled - Card is on its way to Alphacool for a block to be made for it and the AMP version, believe as well it might fit the Gigabyte Mini version but will have to see.
https://encrypted-tbn3.gstatic.com/...PoMUEOI_WUHXrxWQvSZtuauiByBTxVhHvcUyutJiNF3tV
Cooling will be driven via Eisbaer AIO with a 45mm 240 rad at the top since the full height of the Matx board isn't neeed. There will be no QDC and 16/10 compression fittings used.
Unfortunately build will adapt black as the main theme with highlights of white being the board, ram and tubing.
Wingboost/Parvum fans will be used on the bottom and bottom right to drive cold air in and up with the rad exhausting.
build will sit at a few pounds above £1000 which im pleased about
makes up for not having the case white.
I've just seen Coolteks UMX3, which could run the same set up with some modding to have a 240 in the bottom or use current mounting points for a 120 & 140 rad
http://www.cooltek.de/media/image/4250140370556-9.jpg
Although it will be a slow build but this time around its not due to modding GPUS for Hybrids, slowly gathering parts and water block will take a while =/
** Do not Hotlink images **
makes up for not having the case white.I've just seen Coolteks UMX3, which could run the same set up with some modding to have a 240 in the bottom or use current mounting points for a 120 & 140 rad
