Hey all!
Just to let you know that after using a full size case for a couple of months that I miss SFF and that i'm putting together a build to allow me to return to the realm of the "elite"!
Firstly I have a few questions - i'm trying to get this build spot on, so they're spec related.
a) I can't seem to decide on a case. I want small, but at the same time I don't want to be fighting with it when i'm putting stuff in or taking it out. I tried the SG03 and didn't really like it, so that's off the table.
The two i'm down to is the SG01 Evolution and the V350. I'm leaning more towards the V350 due to the 2x120mm fans and the room for a mini-ninja, but I like the styling on the SG01 so much more!
What are people's thoughts? Which would be the better case? What about size? Is one hugely bigger than the other? It's hard to tell from measurements.
It's most likely the Sugo would be paired with an NT06 cooler, and the V350 with the mini-ninja. I'm going for power but low noise with this build.
b) Motherboard. I know i'm going to get *GA-G33M-DS2R* yelled at me, and fine, that's the best mATX board currently available. But is it worth waiting for G45? Anybody know if any of the boards will be good, and how far off they are?
c) Case fans. Of course this depends on the answer from a), but what do people recommend in the 80mm and 120mm fan categories that give a good balance of noise and airflow? Bear in mind this would be sat on my desk and therefore any irritating noise would be that much worse!
For what it's worth, this is what's going in it.
Intel Core 2 Duo E8400
4GB G.Skill PK-6400 4-4-4-12
ATi Radeon HD4870 (most likely, although a GTX260 might find it's way in instead)
Western Digital Velociraptor 300GB
Asus Xonar DX PCIe
Corsair HX620
And a SATA DVD-RW drive of some description, not sure which
Thanks all, sorry about the wall of text, but I want to get this right.
Asus Xonar DX PCIe
Corsair HX620
