A colleague of mine is looking for a small PC for running an officially supported Solidworks VR setup.
It needs to be SFF so thinking itx, single gpu, sfx psu. Smaller the better.
GPU will probably be the quadro P5000 as solidworks in VR seems to be quite the monster.
Needs to have usb C.
64GB of RAM is needed due to their use of other application. I did question this but can't reduce unfortunately. Can you run ECC memory on a non ECC cpu? It seems only the ECC server stuff has big enough DIMMS. SODIMMs seem to be larger too which is odd.
Appreciate anyone that can find a good CPU/motherboard combo that will seat 64GB in itx!
