SFF Spec Help..
18 May 2009
WSM/Teesside
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366)
BFG GeForce GTX 275 OCX 896MB GDDR3 PCI-Express Graphics Card
Asus Rampage II Gene Intel X58 (Socket 1366) PCI-Express mATX DDR3 Motherboard
2x LG Flatron W2261V 22" Widescreen LCD Monitor
OCZ Blade Series 6GB (3x2GB) DDR3 PC3-16000 Triple Channel (OCZ3B2000C9LV6GK)
Coolermaster Silent Pro Modular 700W Power Supply
Lian Li PC-V351B Aluminium Cube Case - Black (No PSU)
2x Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM
Logitech Illuminated Keyboard
Asus SDRW-08D1S-U External USB DVD±RW Optical Drive - Retail (Black)
Lian Li EX-23NB Hard Drive Kit
2x Noctua NF-P12 Vortex-Control 120mm Quiet Case Fan - 3 Pin
Noctua NF-B9 Vortex-Control 92mm Quiet Case Fan
2 x Noctua NF-R8 80mm Silent Case Fan - 3 Pin
Noctua NH-U9B CPU Heatpipe Heatsink with NF-B9 Fan
Noctua LGA1366 SecuFirm2 Mounting-Kit
Boogie Bug AimB.Pad XL Gaming Surface
Ok so theres the spec of a Mini pc i would love to build, but i was kinda put off by the idea, i have an alternative spec for a normal atx sized pc, but i thought i would chuch this up to see what people thought.
Bascially im concerned about the cooling.. and was wondering if people had an idea if this would be sufficiant..
Anyways, im open to all comments and critisiums, and also please tell me i if i have forgotten anything or if there are things which can be improved..
Um I'm pretty sure the Noctua NH-U9B won't fit... The PSU sits over the top of your CPU, so the clearence certainly isn't enough for a tower heatsink.
Also what are you using the PC for? Have you thought of going down the i5 route? I know its new today, but if you look at the prices and gaming performance it looks very tasty.
Mostly using the PC for heavy gaming, 3D moddeling and rendering using maya, Programming, and graphics type work.
This guy has got the U9DX (made an error in the first post) which leaves a clearance of 3mm between that and the PSU.
This is what im worried about, I know there isnt a lot of room in there and would like advice on keeping it as cool as possible.
I have a 1600 budget and would love to build a sff gaming pc just to be different, im uncomfortable with watercooling at the moment, but have been looking in to it and have plans.
