Hi everyone
I'm looking to put together a new SFF machine to take over some duties from my main PC (gaming rig) ie;
Thanks!
- General use (browsing, emails)
- Multimedia playback (music via itunes, downloaded tv eps, movies)
- File storage (of above multimedia mainly), will be required to be left on 24/7
- Case
- Space for 1 x 2.5" SSD and at least 2 x 3.5" HDD's
- Must have very low noise and heat outputs
- USB 3.0 slots on front panel if possible
- No need for optical drive slot
- Around the size of the Lian-Li PC-Q08 if possible
- The Lian-Li PC-Q25 looks the perfect choice so far but doesn't have front USB ports!
- Must look subtle, similar to these mentioned Lian-Li's
- Motherboard
- CPU
- I would like to fit an all-in-one water cooler ie OcUK H²Flo if the case will allow
- Memory
- SSD
- Around 100gb
- PSU
- Must be modular for tidiness
- Graphics card
- Preferably fanless
- Note I will not be gaming on this so nothing fancy required, I do however use a Dell U2711 monitor at 2560x1440 res so video performance may be of consideration
- Sound card (only if budget allows)
Thanks!
