I was wondering what the difference between a single 120mm rad custom loop and a single rad AIO like the one i have, also are there any alternatives to this as the reviews dont seem to be very promising on the noise front.
If you're only going to keep 120mm of rad space, then jut keep your AIO as you will see pretty much no difference at all with a custom loop with a 120mm
