** SFX PSU DOMINATION IS HERE - SILVERSTONE SST-SX600-G '600W MODULAR 80 PLUS GOLD' INTELLIGENT FAN
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
First to Market! OcUK once again with the sharpest pencils :cool:
Coming soon to OcUK and available to pre order now, the 600W SFX Modular PSU from Silverstone is pretty much the most bad ass SFX on the planet.
announced a while ago and featured heavily in nearly every tech review sites computex coverage, this thing has the SFF community buzzing. With ratings usually not even seen on full size units, this supply is perfect for small builds with power hungry GPU and CPU requirements.
Perfect for the Silverstone Sugo range as well as the upcoming Parvum ITX chassis, the SST-SX600-G is a technical masterpiece.
Available for pre order right now, we are expecting stock over the coming weeks.
Silverstone Strider SFX 600W Fully Modular '80 Plus Gold' Power Supply (SST-SX600-G) @ £99.95 inc VAT
After releasing the breakthrough SFX power supply in 2012 with the ST45SF-G, SilverStone has pushed the technical envelope even further with yet another industry defining design in the SX600-G. This small form factor PSU has the exact same dimensions as its predecessor but its power density has increased from 567W per liter (in the ST45SF-G) to 756W per liter. The result is a standard-sized SFX PSU with an incredible 600W of continuous power, a level that is capable of supporting any single graphics card system with ease.
Besides the power increase, the SX600-G comes standard with flexible, flat modular cables similar to those in the PP05-E short cable kit for vastly improved cable management in smaller cases. It also has added semi-fanless capability that was first introduced to SFX PSUs by the ST30SF so its quiet running fan can remain turned off during ideal low load or idle conditions for complete silence. As before, an ATX adapter bracket is included to enable users to install this PSU into any small or even larger cases that do not have SFX mounting holes. For the most ardent SFF enthusiasts, the SX600-G is truly a dream come true that combines the convenience of SFX size and all the top of the line features one can expect from high-end ATX PSUs into one product.
Features:
- Intelligent semi-fanless operation
- Support standard SFX form factor and ATX via included bracket
- High efficiency with 80 PLUS Gold certification
- 100% modular cables
- All cables made with flexible flat arrays
- 600W continuous power output at 40? operating temperature rated for 24/7 operation
- Class-leading single +12V rail with 50A
- Strict ±3% voltage regulation and low ripple & noise
- Support dual PCI-E 8/6pin connectors
Specification:
- combined +3.3, +5V: 90W
- combined +12V: 600W
- Input Voltage: 90V ~ 264V
- Input Frequency Range: 47Hz ~ 63Hz
- PFC: Active PFC(PF>0.95 at full load)
- Efficiency: 87%~90%(20% to 100% loading)
- MTBF: 100,000 hours
- Operating temperature: 0°C ~ 40°C
Protection:
- Over current protection
- Over power protection
- Over voltage protection
- Over Temperature Protection
- Under voltage protection
- Short circuit protection
- No load operation
Connectors
- 1 x 24 / 20-Pin motherboard connector(300mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(400mm)
- 2 x 8 / 6-Pin PCIE connector(400mm / 150mm)
- 4 x SATA connector(300mm / 200mm / 100mm / 100mm)
- 2 x 4-Pin Peripheral connector (300mm / 200mm)
- 1 x 4-Pin Floppy connector(300mm / 200mm / 200mm)
- Color: Black(Lead-Free Paint)
- Cooling System: Single 80mm silent fan
- Noise Level: 0 ~ 40 dBA
- Dimension: 125 mm (W) × 63.5 mm (H) × 100 mm (D)
- Weight: 1.45 Kg
- Form factor: SFX
- Certification: 80 PLUS Gold
Was [OLDPRICE] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
litre is spelt wrong in the description. You have spelt it liter.
Also it is £100 but the best SFF on the market by the looks of it. You pay for what you get.....
Seen one of these not too long back and it is so small. The power that is inside one of these things is amazing. totally worth £100 if you are making a sff build.
If you don't particularly need 600w, i'd get the ST45SF-G.
Even a 295x2 system I saw was drawing less than 700W power under load, and they recommend a 850W PSU minimum for that beast of a GPU.
Yeah, I have read that the 450W models are very good for what they are. Seeing as I will be using all the connectors I might as well go for the bronze one I think, bit cheaper but just as well built and apparently quieter.
Will OcUK be getting the other SFX psus back in stock on the same date you receive this new model? 16th Sept?
I have the 450 model in my LAN rig and its a little star.. Probably not pushing it as hard as I could but no complaints... 600W in that formfactor is crazy.
