- 15 Sep 2007
Hi all,
Considering a SFF solution at the moment, a constraint for me is that the device will be placed inside fitted furniture in our dining room - the width of the enclosure is 264-265mm. Height and depth won't be a problem.
I've been looking at the Silverstone cases, however the smallest case SG01 has a width of 263mm, which leaves at best 1mm clearance either side.
There appears to be a side vent on the case... should I be ditching this as an option and going for a shuttle instead?
Thoughts appreciated
sp.
sp.
