You would probably just about get away with it, but your best bet would be to get the Silverstone Strider ST45SF 450w just to make sure. I recently fitted one to mine in preparation for a 460 1gb.
Did you put a H50 in your case?
eek and your cpu is?
at 160w for the 460 and then at least 110w for the cpu (regardless of what it is) you will be on the edge put it that way!
a 400/450W PSU would be a wise decision or get something like a 8800gt that uses less power but still has some grunt.
From individual card reviews i think both 5770 & 460 both pull well into 200w when under heavy load.
I run a 5770, a core2 oc 4gb ram and a ssd and the psu does get warm with games. I would consider the 450w psu just to be safe and prolly mor efficient.
Yes. You need to remove the hdd cage and it limits the length of the GFX card to around 8.5", but it does fit![]()
