SG05 Spray Painting Help.
11 Sep 2008
Northamptonshire
Just ordered a SG05 just want to know what spray paint i should use to paint it black, Planning on heading up to BNQ to pick up some spray paints. Also could do with a quick guide to follow :)
being a painter and decorator.. Im usless:D
cheers.
Key the surface, go back to metal if possible. Use an etching primer, lightly sanding with a high grade wet and dry between each coat, same with the colour and finish with a good few coats of laquer/clear coat.
cheers.
why didnt you just order a black SG05? :D
yeah i thought that.. I just bought a black one.. :)
I have purchased 5 of these and have had every single one either powder coated or wet sprayed as the finish from Silverstone is cack IMHO.
Takes about half an hour with a power sander to get one naked.
Nice cases though. :p
