sg05 with 7950
14 Aug 2011
London/Cambridge
Hey guys, I was wondering if it was possible to fit a twin frozr 3 amd 7950 in the sg05?
It's dimensions are supposedly 10.28 inches which is around 262mm and therefore seems just small enough to fit but manufacturer's are sometimes dodgy with they way they measure their cards. I've seen people online with the 10.5 inch powercolour inside one, but then like I said, every manufacturer measures differently.
I hear the sg05 has an internal length of of 267mm. Can anyone confirm this?
Will the 7950 have trouble with 450 watts? instead of buying the case with bronze psu built in outright for around £115 I can buy the case seperately for around £35 and the gold version of the sfx psu by silverstone for around £80 if that will help?
I get 263mm internally. I believe that card will actually fit but it is a very tight squeeze.
Cheers guys. I've just seen the kfa 670 has gone down in price so I may get that instead as it's smaller, with power comparable to a 7950 and there are members who've managed to get that specific 670 in without modding.
