SG31G2 Noise !!
31 Jul 2004
Just built up a SG31G2 for a media center and I am very dissapointed with how noisey it is :mad:
Problem seems to be the PSU but I'm not sure the 40mm fan is the only problem
IMO 40mm fans should not be any part of a quit PC
Anyone managed to quieten down one of these PC's ?
So far I'm pleased with the performance just the noise and ultra bright power LED's Issues
Yes Led problem is simple enough..;)
PSU is a bugger as in early building I took the PSU apart as I don't think all the noise is from the Fan...some sort of hum/buzz from the (switch mode circuit) I'm guessing, did Your friend go for a PC50 ?, looks like they have 2 40MM fans but are thermostatically controled
Well I suppose the point is "quiet" has different meanings to everyone !
The system is pulling 90W total from the 250W PSU, thats not heavy Loading.
I've ordered a PC50 which claim to be silent...I will see
Maybe I'm comparing to Ideqs which I really think are better in lots of areas compared to the Shuttles
I really think you should look at other components before the PSU. I really mean that the PSU on my shuttle is near silent to start with, the main culprite for noise is the fan on the ICE, harddrive and gfx card.
