In GTA and one of the half life games the games detail goes black.
I have a hd4850 on stock settings running at default settings on ati catalyst.
I am using 8.12 drivers and also had the problem using previous drivers.
http://e.imagehost.org/view/0142/problem
The screenshot above gives you an idea of what it looks like, basically everything goes black with no color
HD4850
c2d e7200
2gb ram 800mhz geil black dragon
Windows XP SP3 i think it is
ATI 8.12
EDIT with more information provided here:
I put fan on 100% and temps were always under 68c according to gpu-z
HL2 @ low settings and performance under catylst 8.12
http://e.imagehost.org/view/0749/low
HL2 after i alt+tabbed to take the screenshot (Windows and glass etc was purple)
http://e.imagehost.org/view/0979/alt_tabbed
HL2 on high graphics and performance under catalyst (game crashed when changing graphics while game was live)
http://e.imagehost.org/view/0984/change_graphics
HL2 on high graphics and performance under catalyst (When i changed settings and restarted the game)
http://e.imagehost.org/view/0970/final
HL2 on high graphics and highest quality on catalyst
http://e.imagehost.org/view/0730/catalysy_high
When i move throughout the map walls completely disapear and it makes it impossible to move as i cant see if im inside a room or outside. The textures also double up like it had been produced 5x and all stay on the screen
This problems has occured using 8.10 and 8.11 versions and the current 8.12 so i cant see it being a driver issue.
I have formatted using a clean install.
Everything on my pc is currently at stock and graphics card has never been overclocked
HD4850
c2d e7200
ATI 8.12
