- 25 Jan 2021
Hi guys,
Recently asked for help regarding choosing a CPU cooler as the Intel stock was simply worrying in regard to the temps I would receive, this has improved significantly since purchasing the Shadow Rock 3, but my issue is that as it's very tall it's such as snug fit in my case. It's working perfectly and my temps seem fine, but is this an issue since the top of the heat sync is only just touching my case, would this cause an issue?
Everything seems ok, the side of my case feels warm, but not hot.
New to all this cooling, is it worth getting a different CPU cooler?
https://imgur.com/a/DpBRbWP
Image above
Thanks
Image above
Thanks
