Shadows when scrolling on Samsung S34E790C
27 Nov 2003
Hi all, I have the above monitor with GTX 980,
When I scroll and play games, this black shadowy effect appears as I've captured on my phone here:
https://imgur.com/a/SCgP7AI
I've just installed the latest drivers etc, but seems to be persisting, any ideas?
Thanks in advance
Thats VA for ya. Its an older panel from samsung and a va type as well. THey do not play nice with dark transitions. You may be able to reduce it depending on what kind of overdrive setting is available.
Typical VA panel issue a Phixsator has pointed out but you should be able to reduce this by changing the response time setting in the monitors menu system i believe there are three different response time modes like standard /faster and fastest available, try standard.
