shakey display
31 Aug 2005
I am not sure where to post this but here goes. I am currently running the spec in my signature however when I play certain games the display shakes from side to side.
It is perfectly fine within vista and say football manager 08. However if I load up the unreal tournament 3 demo, crysis demo, Company of heroes: opposing fronts or world in conflict the display starts to shake.
If I then minimise to desktop the display will keep shaking until I exit the game. I am running the catalyst 7.10 drivers.
Sorry should have said i am running vista at 1680x1050. and have tried running all games at various resolutions.
1) YOUR SIG IS TO BIG READ THE FAQ, ONLY 4 LINES, SORT IT OR YOU WILL BE BANNED
2) Sounds odd do black bars appear either side? is it 'fast' or 'slow' shaking.......sounds like the monitor trying to auto adjust or something, but it should only do it when you press the button on the monitor
EDIT: and 3) Dont bump threads 2 mins after u have posted them, your likely to get banned for that as well
1 i have sorted out my sig thanx.
2 there are no black lines the display takes up the whole screen.
3 i bumped this 4 days after i posted.
You donrt get banned for bumping nor do you get banned for having a sig to big lol.
Ive had a shaky screen before, cant remeber why though. Have you checekd all connections? Though it would do it constantly if taht was the case. You tried a differnt screen?
