Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi. i have been building pc's since the old Viglan machines running windows 3.1 and up until this day i still have not took the courage to try out water cooling.
is it safe to do nowadays? are water cooling kits still prone to leakes? i heard there is a special liquid to use called non conductive? does that mean if it leakes it wont damage your components?
How much does it cost to water cool a GPU and a cpu using a decent kit?
This is the case i have http://www.techpowerup.com/reviews/LianLi/PC-A7010/4.html
It has a i7 920 inside along with a 480gtx which is blooming loud and hot
