Shall I push my 2500k further?
23 Jul 2007
Hi guys,
Really chuffed with this chip :)
my 2500k is now running @ 4.7ghz - full load temps are around 56 on cores 3 & 4 and 52 on 1 & 2. Idle I'm around 20-23 so very cool indeed.
Seems perfectly stable with 1.27 vcore. What is acceptable temp wise on a 2500k? Shall I go for 5Ghz? This is for everyday use so I don't want crazy vcore or temps.
Cheers!
Wow, thats quite an overclock on those volts. I'm having to use 1.345v to get 4.6 out of mine :(
I think Sandybridge cpu's are more limited to voltage, I think 1.38v is the extreme safest voltage. But I think its 1.32-1.35v is recommend by OcUK. Theres a stick somewhere, in CPU or the overclocking section
Go go go go!!!!!! Overclock it, that's a golden chip you have there by the looks of things.
Corsair A50 cooler and IC Diamond paste.
I've just tried pushing the chip a bit further but it seems 4.7 is the sweet spot for clock/vcore - 4.8 requires 1.3 vcore.
I may keep going though. The temps have hit 63 on 4.8ghz 100% load. normal load say 50% and its mid 30's so still pretty cool.
I will report back if I can hit a stable 5ghz!
Yep go for it,with those volts you might be looking @ 5.2. If it does do 5.2 get the thing sold on ebay :) you will make some money there.
What are you testing the stability of the chip with? Can't really believe that it's stable at that voltage for that clock. Have you tried IBT with the latest linpacks (you should be getting 120gflops) to test for temps and stability.
Agreed. That seems too low a voltage even if you got a golden chip mate:D
Prime95 - and plenty of games. No crashes.
That is stable in my book I'm not a hardcore overclocker or anything :P - I just need it stable for normal usage (games!) and that it is!
I don't think I ever used to stress test my older cpu's - If I didn't get bsod's or crashes they were stable as far as I was concerned!
Edit (the vcore fluctuates between 1.272 and 1.28. So its not quite 1.27)
Edit (the vcore fluctuates between 2.72 and 2.8. So its not quite 2.7)
?? I am guessing typo and you ment to say 1.272 and 1.280 ? 2.7 vcore would cook a fried breakfast for the entire country before you chip turned itself to glass. Unless you are siting the entire rig in a vat of Liquid N2 :)
Also when you are running prime95 are you running all 4 workers ? Reason I ask is first time I ran prime95 blend I was only running 1 and it makes you think that the chip can clock high on super low volts but as soon as a corrected my error and ran all 4 threads 1.25 volts @ 4.6 was quite clearly not enough juice ;)
Obviously people have different standards of stable. Mine is no crashes + will do prime blend & fft tests for a few hours without failures. I am not a 'bencher', All I was asking in the first place is whether I should push it some more or just leave it be as I am not an expert overclocker... I wasn't posting to brag or anything?!
@@wildman
Yes sorry typo. It is definitely running all 4 cores. :)
Where do I find these latest linpacks? searched but couldn't find anything.
I'm using IBT v2.50 but the highest i'm getting is 71.5 GFlops @ 5Ghz
Just out of interest, what motherboard you using? And what are most of your bios settings?
With my Asus I still don't think I've found the sweet spot with all these overclock settings.
Not really. There is only one standard of stable i.e it either is or isn't. It can either do everything that same way it left the factory or it can't, there's no middle ground :) If it can take 8+ hours of small & large fft plus 50 passes of linpack (linx has a better ui that itb btw), basically if it can take everything you throw at it, then it's stable.
What people have is varying standards pertaining to the margin of error. What person a considers acceptable risk is not necessarily what person b considers acceptable.
Oh and blend cycles blocks trough the memory, it's large (but mostly small) ffts that test the cpu but prime only tests a cpus ability to handle floating point workloads.
